boggs down when in gear
Old Jun 17, 2012 | 02:29 PM
Jared Miller's Avatar
Jared Miller is on a distinguished road
Angry
i am stompted i have a 2000 chevy blazer zr2 six inch lift 32in tires... my problem is that when the car is idleing it is fine but as soon as i try to put it in gear it wants to bogg down and have no power i recently changed fuel pump fuel filter... we think it could be the fuel pressure regulator but its a pain to get to so befor i do that is there any other ideas it could be... very appreciated
another issue i hooked of fuel pressure gauge and it read 15 psi key on engine off when i started it,, it went to 50 psi so i changed fuel filter now its not reading zero psi but there is pressure cause when unhook fuel gauge it sprays fuel...
Last edited by swartlkk; Jun 17, 2012 at 02:42 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Jun 17, 2012 | 02:43 PM
These engines require >55psi to run properly. 15psi is NOT enough. Follow through the entire procedure listed in the 96+ fuel system diagnostic link in my signature below and report back the results. It should help you pin-point the actual failure in your fuel system for accurate repair.
Old Jun 17, 2012 | 03:07 PM
Thanks
2000jimmbo4x4
Sep 14, 2010 08:51 PM
Kendo
Sep 22, 2009 11:12 AM
Fat_Phil
Feb 20, 2009 10:48 PM
goldie
Aug 25, 2008 11:19 AM
99 Blazer 4x4
Sep 6, 2007 05:06 PM
