Bolt information near upper control arm 1999 Blazer 2wd
Old May 19, 2010 | 07:14 PM
ryanleh's Avatar
ryanleh is on a distinguished road
Default Bolt information near upper control arm 1999 Blazer 2wd
Today on the way home from work I felt a slight change in my steering. When i got home I took a look near the tire (That looked like it was going to fall off) and seen that a bolt had broken. It looks like the retaining Bolt that goes through the control arm shaft? Bolt goes through a bracket welded to the frame right under the upper control arm. The bolt goes through the bracket and through the control arm shaft. Can anyone elaborate on my problem let me know the size of the bolt. Can I simply get this bold at the auto-parts store and put it in by slipping it under the control arm? Is it going to come out (I have not tried to punch it out yet) Why would this bolt break should I look into replacing something that might have caused this? Any help would be great!
1999 Chevy Blazer just purchased for 3K my wife is going to kill me as I already have to replace the heater core.. Or have it done..
This is a picture of the bolt I think I am talking about...
Attached Thumbnails Bolt information near upper control arm 1999 Blazer 2wd-retin.jpg
Last edited by ryanleh; May 19, 2010 at 09:57 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 19, 2010 | 07:33 PM
*Moving to 2nd Gen Tech* - The Chop Shop is not a place to post technical questions... Please read the descriptions of the sections and choose the most appropriate forum to post your threads in based on the nature of the question.
I don't know the size off the top of my head, but I can say that it would not be a general purpose bolt. If it were UNC thread size (ie. not metric), it would be a grade 8. Without looking it up, I couldn't tell you the metric equivalent for a grade 8 bolt. You would likely need to get it from a hardware store.
You are going to want to get an alignment done afterwords because I doubt that all of the shims stayed right there.
Old May 19, 2010 | 09:09 PM
Dan 128's Avatar
Dan 128 is on a distinguished road
I agree that you shouldn't use a standard grade 2 or 5 you should use a grade 8 bolt. I would also check the rest of the bolts for damage. These bolts just don't break some thing caused it and there's probably more damage.
Old May 19, 2010 | 09:57 PM
ryanleh's Avatar
I was thinking of using the
1995-2005 Chevrolet Blazer Front Suspension, Upper Alignment Kit - Moog they are basically bolts that I assume go into this location but I am unsure because I read that sometimes you have to modify the shim to get it to fit correctly. See picture I will post someplace here ect.
Old Sep 3, 2011 | 08:46 AM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
Question Update?
(ryanleh) I know its over a year past when you posted, but I currently find myself in the same situation. I was wondering how the whole bolt search went...I think my bolts are stripped out, or something. It seems like I have to take the truck into the shop every 1000 miles because my drivers side wheel is about to fall off...and worst part is that I have a broken knee and leg, so I cannot crawl under my truck anymore!
BIGJEFF64
Sep 28, 2014 07:35 AM
ExpressEN1
Dec 14, 2012 09:35 PM
haulincats
Oct 5, 2011 07:46 PM
blazer37
Aug 22, 2009 11:37 AM
LONGER
Sep 1, 2008 08:05 PM
