fuel pump
Old Sep 2, 2011 | 04:40 PM
JasonDon's Avatar
JasonDon is on a distinguished road
Default fuel pump
I have a 97 blazer. I am replacing the fuel pump and the pump I bought online has a new harness. It has a purple wire, grey, solid black, and black with a white line. On my truck i have purple,grey,and two solid blacks. Can anyone help?
Old Sep 2, 2011 | 05:01 PM
pettyfog's Avatar
Cool
What about the directions that came with the pump?
Old Sep 2, 2011 | 05:57 PM
LRV31's Avatar
LRV31 is on a distinguished road
Instructions?? Who reads instructions?
No really, that would be a good place to start.
Old Sep 2, 2011 | 06:00 PM
aneill75's Avatar
aneill75 is on a distinguished road
This might help. You should have a black/white wire, though (look again). If not, tag the wires BEFORE cutting off the old connector.
Plug pinout (courtesy of Swartlkk)
Aaron
Sure, but the wiring code is the SAME as the truck. No directions needed......... unless you need splicing instructions. Although, I might glance at them to verify that the Manufacturer is indeed correct LMAO!
Old Sep 3, 2011 | 01:56 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Instructions are what your wife reads when you're finished with the job and it still doesnt work.
Old Sep 3, 2011 | 10:25 AM
TouringMike's Avatar
TouringMike is on a distinguished road
Your existing two black wires should be different gauges.
Connect the larger size black wire to the solid black on the new harness.
Connect the smaller black wire to the blk/wht wire on the harness.
Solder these connections together. Crimping only will lead to future failure.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
