Book labor time for replacing fuel pump?
Old Feb 12, 2013 | 04:09 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Default Book labor time for replacing fuel pump?
What is the "book" labor time to replace a fuel pump on a 1998 Blazer 4x4 4dr w/steel tank?
Old Feb 12, 2013 | 04:45 PM
2.3 hours
Warranty time, which is very close to actual time, is 1.5 hours.
Old Feb 12, 2013 | 05:16 PM
WalkGood's Avatar
Thanks. Can u tell me what source u r using? PepBoys is telling me $488 labor to R&R my fuel pump. I need some "backup" to question them. $310 for ACDelco pump
Old Feb 12, 2013 | 05:34 PM
Those labor times are from the current Chilton Labor Time Guide. I have used Chilton labor guides for many years and have found them to be quite accurate. The Chilton service manuals are worthless though. Mitchell labor guides tend to be a little on the high side. $488 for labor calculates to $212.17 per flat rate hour, (more than double the national average). $310 for an AC Delco (4 door) fuel pump is actually not bad considering you're paying retail price, but they're sure making up for it on the labor!
Old Feb 12, 2013 | 08:12 PM
WalkGood's Avatar
I am not sure where they came up with $488 labor. I know if they did the job in 1 hr they would charge the book time. Not sure but I think my Long Island NY area is around the $120 to $125 an hr labor rate. And they did charge $90 diagnosis for the "crank-no-start" problem.
At least Pep Boys service does not mark up parts from the price you would pay at their parts dept.
I'll go question them tomorrow when I pick up the car.
Old Feb 25, 2013 | 08:43 AM
WalkGood's Avatar
BELATED UPDATE:
I went to my public library and used their free AllData access. Alldata shows 1998 4x4 4door metal fuel tank: labor to replace fuel pump is 3.2 hours plus 0.5 hours with a tank shield (which I have a shield). It notes that "Does Not Include: Drain & Refill Fuel Tank". I could not find a separate labor time for Drain & Refill within AllData.
PepBoys "book labor charge" for this job is 4.4 hours @$111.00 per hour. Luckily I found a 10% OFF coupon on their website. Applies towards parts and labor.
Old Feb 25, 2013 | 09:54 AM
newguy's Avatar
I did mine in my backyard with hand tools and it only took me 1 1/2 hrs. And that is desiring the harness also. Not a hard job
Old Feb 25, 2013 | 11:14 PM
WalkGood's Avatar
I was in that "rock and a hard place" position. Freezing temps and a major blizzard on its way (dumped over 30 inches on Long Island). If it was warmer weather I'd probably do it myself.
I have desired many things FOR my vehicle. But, never did "desire" a harness! LOL
Old Feb 26, 2013 | 02:02 AM
newguy's Avatar
Should have proof read before posting, meant rewiring
Old Dec 5, 2017 | 07:00 PM
PSS-Mag's Avatar
PSS-Mag is on a distinguished road
I'm in that same hard spot now. Blazer is in the shop. Next to my work. I don't even have time to meet up with a buddy to pull it home much less wrench on it. So I had it towed to the shop next door. Literally a block a way. That tow bill blew my mind. ($55) for less than 3/4 a mile! Probably closer to half a mile. Never again for that. Anyway, they called me today said 'fuel pump" which I suspected. Wasn't getting fuel for some reason and couldn't hear the pump running. Checked fuses and swapped relays with no results. Anyway they quoted me $678. I checked prices and I can pick one up before my discounts for $200-$269 locally. So $400 in labor seems a little steep but time and currently no garage and laying outside in the dark in sub freezing temps. Guess I'll pay the $400. Lol
