Book labor time for replacing fuel pump?
Those labor times are from the current Chilton Labor Time Guide. I have used Chilton labor guides for many years and have found them to be quite accurate. The Chilton service manuals are worthless though. Mitchell labor guides tend to be a little on the high side. $488 for labor calculates to $212.17 per flat rate hour, (more than double the national average). $310 for an AC Delco (4 door) fuel pump is actually not bad considering you're paying retail price, but they're sure making up for it on the labor!
I am not sure where they came up with $488 labor. I know if they did the job in 1 hr they would charge the book time. Not sure but I think my Long Island NY area is around the $120 to $125 an hr labor rate. And they did charge $90 diagnosis for the "crank-no-start" problem.
At least Pep Boys service does not mark up parts from the price you would pay at their parts dept.
I'll go question them tomorrow when I pick up the car.
BELATED UPDATE:
I went to my public library and used their free AllData access. Alldata shows 1998 4x4 4door metal fuel tank: labor to replace fuel pump is 3.2 hours plus 0.5 hours with a tank shield (which I have a shield). It notes that "Does Not Include: Drain & Refill Fuel Tank". I could not find a separate labor time for Drain & Refill within AllData.
PepBoys "book labor charge" for this job is 4.4 hours @$111.00 per hour. Luckily I found a 10% OFF coupon on their website. Applies towards parts and labor.
I was in that "rock and a hard place" position. Freezing temps and a major blizzard on its way (dumped over 30 inches on Long Island). If it was warmer weather I'd probably do it myself.
I have desired many things FOR my vehicle. But, never did "desire" a harness! LOL
I'm in that same hard spot now. Blazer is in the shop. Next to my work. I don't even have time to meet up with a buddy to pull it home much less wrench on it. So I had it towed to the shop next door. Literally a block a way. That tow bill blew my mind. ($55) for less than 3/4 a mile! Probably closer to half a mile. Never again for that. Anyway, they called me today said 'fuel pump" which I suspected. Wasn't getting fuel for some reason and couldn't hear the pump running. Checked fuses and swapped relays with no results. Anyway they quoted me $678. I checked prices and I can pick one up before my discounts for $200-$269 locally. So $400 in labor seems a little steep but time and currently no garage and laying outside in the dark in sub freezing temps. Guess I'll pay the $400. Lol
