Bout ready to cry.....help
Old Jun 2, 2010 | 10:50 AM
DINKERV's Avatar
DINKERV is on a distinguished road
Default Bout ready to cry.....help
Ok, here is what i have, 1999 two door 4x4 4.3 auto. Ran perfect then.....started up.. And immediately dies, i've checked everything...relays, fuel, fueses, finally with advice from mechanic friends everyone decided it was the fuel pump, well..340.00 at autozone i bought an entire new fuel pump....and installed. Guess what? Does same thing, will start then die, start, then die, will not stay running. It's showing no codes, i'm beat....any ideas????
Old Jun 2, 2010 | 11:12 AM
kjmitchell's Avatar
kjmitchell is on a distinguished road
did you check the spider injector?
Old Jun 2, 2010 | 11:29 AM
wlorton's Avatar
IS the security light on?
Old Jun 2, 2010 | 11:45 AM
84BlazerS10's Avatar
Is there any active codes?
Old Jun 2, 2010 | 01:31 PM
jigger's Avatar
jigger is on a distinguished road
Did you change the fuel filter with the new pump?
Did you replace the sock in the tank with the pump?
Did you do a fuel pressure test?
Old Jun 2, 2010 | 07:08 PM
mrshaneb's Avatar
mrshaneb is on a distinguished road
To the OP, my 97 is kind of doing the same thing. Checked the Fuel Pump and Fuel Pressure all are fine. New Ignition Switch and Cylinder. The Dealership is puting in a New Starter tomorrow, not sure if this will correct the problem but, I am so hoping it does.
Old Jun 3, 2010 | 07:07 PM
DINKERV's Avatar
Default Well...
I have not checked the spider, hoping to find a fix with out taking the engine apart....fuel press. Good, no codes, no security light....but one caveat...the sucurity light had come on rare instances but not now?? Still stumped,
Old Jun 3, 2010 | 07:20 PM
mrshaneb's Avatar
Check the Fuel Filter.
dropwiser
25
Mar 5, 2013 10:24 AM
Dolanjohn1990
Feb 11, 2012 04:07 AM
lloyddavid
Dec 17, 2011 10:02 PM
ChevyBlazerChick
Aug 22, 2011 01:03 PM
T1g4h
Jul 16, 2008 09:59 PM
