Brake Booster going bad
Old Sep 21, 2010 | 05:15 PM
jonnyisback's Avatar
jonnyisback is on a distinguished road
Default Brake Booster going bad
I believe my brake booster is going bad which is causing a woosh sound when i pump the brake pedal and causes a fluctuation of engine rpm as i pump the brake pedal (like its causing a vacuum leak. Here are a few video examples. Also when the engine is running and i pump the brakes my rpm will drop about 200 rpm and then cause the engine to run rough for a second or two and then it goes back up. Let me know what you think.
http://s446.photobucket.com/albums/q...t=MVI_0487.mp4
Old Sep 21, 2010 | 10:36 PM
4x4blazerguy's Avatar
I must of missed it but & didn't hear anything on the video that you linked. Have you checked the hoses? But it is possible to have it leaking.
Old Sep 21, 2010 | 11:58 PM
I have sprayed carb cleaner around all the ends of hoses on it to see if it caused the engine to speed up which it didnt. I have also replaced the vacuum hose which didnt help. The vid has sound for me, you may want to check the volume. I can hear the woosh it makes from inside the cab or under the hood. Sounds like its coming from inside the brake booster.
Old Sep 22, 2010 | 12:02 AM
One way to find out is disconnect the vacuum going to the booster & see what happens. Just remember you will be without power brakes so don't go racing off.
ComputerNerdBD
13
Oct 24, 2017 09:59 AM
dshuld
Feb 17, 2011 09:59 PM
consernedguy
Nov 6, 2006 11:19 PM
JCG1
Suspension Tech
Sep 19, 2006 02:07 PM
khalid_20879
Jan 3, 2006 01:00 PM
