Brake Booster or Something Else?
Old Mar 31, 2023 | 11:18 AM
fiveskis's Avatar
fiveskis is on a distinguished road
Default Brake Booster or Something Else?
My brakes started feeling a little soft and then got to the point where the pedal went to the floor with no stopping power. So I started looking into the brake system and found some corrosion issues and replaced some lines, replaced the MS (twice) and did other troubleshooting. Pressure bleed the brakes multiple times, used my Scanner on the ABS, bench bled the new MC and isolated parts of the system to try and solve the problem. When the car is off and press the pedal a couple of times, the brake is firm and hard. However, upon starting the Blazer, the peddle goes soft and travels to the floor.
I have also capped off the MC ports with plugs and got the same scenario: firm brake when off, but pedal goes soft when car turned on and boost applied. I have checked the booster check valve (good), booster line (good) and no visible leaks at MS or Booster. I am getting no rough idle or Check Engine or ABS lights.
It appears to be pointing to the Booster, but these symptoms aren't making sense (a bad Booster or not) - can anyone help or point me in a better direction? Is it time to replace the Booster?
This is a 2000 Blazer LT with 2WD 4.3L and has over 200K miles.
Last edited by fiveskis; Mar 31, 2023 at 11:40 AM. Reason: Put vehicle info into post.
Old Apr 2, 2023 | 04:04 PM
Stovey's Avatar
Stovey will become famous soon enoughStovey will become famous soon enough
Maybe try pinching the hose from the booster to the intake with vise-grips. If the brake pedal then acts normal, this might indicate a leaky brake booster.
Old Apr 2, 2023 | 06:16 PM
If the brake booster has a leak, I would guess it could also affect the engine due to there being a vacuum leak. Is your engine working fine or change how it runs when you depress the brake?
Old Apr 4, 2023 | 12:49 PM
fiveskis's Avatar
Strange - I put the wheels back on, dropped it off the jacks and was backing vehicle out of shed - and I now have brakes! I believe the first "new" MC was bad, but the second is working. I have a good firm brake.
princered72
Jul 29, 2012 03:14 PM
valeria1782
Nov 17, 2010 11:59 AM
lroman3
Apr 16, 2010 02:51 PM
dashyman
Jan 12, 2007 11:28 AM
whistle
Nov 20, 2006 12:42 PM
