brake issues
Old Feb 15, 2009 | 02:26 PM
blazer4x4's Avatar
blazer4x4 is an unknown quantity at this point
Default brake issues
About a month ago i put new pads all the way around and rotated the rotors and now the brakes are not operating correct. It feels like the abs is getting activated. Cause I can hear it and feel it in the pedal when i stop. I was wondering where the abs sensor is so i can check it and see if this is the problem
Old Feb 15, 2009 | 02:59 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: brake issues
I`m not understanding what you mean when you said you (rotated) the rotors!!!
Old Feb 15, 2009 | 11:07 PM
blazer4x4's Avatar
sorry i meant turned the rotors not rotated
Old Feb 15, 2009 | 11:28 PM
Blazin_Jason's Avatar
Pull out the ABS fuse and try driving it around that way to check.
Old Feb 16, 2009 | 06:35 AM
2002XTREME's Avatar
ok thats more clearer on the turned part, did you yourself turn the rotors or a shop did it, or auto parts store? Theres a very good chasnce that the rotors were not cut correctly on the machine.. Do you kinda get like a pulsating feeling to the pedal? I have abs on my 93 chevy van and even on that theres no reason to have to even disconnect the wire to get the rotors off.. that shouldnt cause a prob with the abs by taking the rotors off.. make sure that you didnt get any grease from the bearings on the abs wheel!!! that will def mess with the ABS sensor..
zach bjorge
Mar 17, 2011 06:49 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
