Brake Light
Old Jan 10, 2010 | 12:04 PM
zeedeevil21's Avatar
zeedeevil21 is on a distinguished road
Default Brake Light
00 blazer 4dr......as of last night...the brake light is on..pedal feels a little spongy while driving... when off the pedal hardens right up....dont see any leaks and fluid is not missing from master cylinder....could this be due to something frozen from ice/snow?
Old Jan 10, 2010 | 04:53 PM
Peel01's Avatar
Peel01 is on a distinguished road
When is the last time you flush the old brake fluid out?
Old Jan 10, 2010 | 06:41 PM
awe341's Avatar
awe341 is on a distinguished road
It's always possible that the cold/snow has caused an issue. But it could just be a normal failure as well.
If you havn't done any brake work lately, and your fluid levels are good with no leaks then it is time to start checking the vacuum and electrical connectors on your master cyl and abs system. (I'll assume for the moment that all pads are good and there is no pulling indicating a bad caliper)
The main vac line from the intake to the master cyl should be checked first.
zjones_85
Jul 5, 2013 05:13 PM
ssboy81
Mar 15, 2012 07:58 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
megtom2
Nov 24, 2007 10:36 AM
