Brake Lights Do Not Work
Old Oct 31, 2010 | 01:42 AM
BlaziNator's Avatar
BlaziNator is on a distinguished road
Default Brake Lights Do Not Work
Hello all. I have a 1995 S-10 Blazer 4x4. A while back, my brake lights stopped working. They come on with the headlights, and the turn signals work on bot sides. However, nothing happens when I tap the brakes, including the LED third light. I checked the fuses on the side of the dash and they all looked ok. I swapped the brake light fuse with a new one just in case with no change. I am lost when it comes to electricity. Can someone point me in the right direction?
Old Oct 31, 2010 | 03:23 AM
robertr728's Avatar
robertr728 is on a distinguished road
There is a switch on the brake pedal. It could be bad or it could be the turn signal switch or possibly that both bulbs are bad. But i would guess hte brake switch on the brake pedal from the sounds of it.
1 check fuse 1 a 20 amp brake/hazard fuse. turn on the headlights and then turn on the hazard lights. If all 4 corner lights blink then im guessing the turn signal switch is ok.
2 with a test light you need to check for power at the brake light switch then press the brake pedal and check for power at the other side.
project85
Jan 15, 2015 03:23 PM
96jimmyslt4x4
May 29, 2011 03:55 PM
95LT
Dec 21, 2010 01:46 PM
charlesw
Oct 15, 2010 07:45 PM
hantayo13
Jan 12, 2008 12:34 PM
