brake lights staying on
Old Jul 8, 2011 | 08:01 AM
szls188's Avatar
szls188 is on a distinguished road
Question brake lights staying on
1999 Blazer 4X4 all 3 brake lights are staying on anyone have this same problem thought it mignt be the CHMSL Relay but my model its not used
can try stoplight switch or multi function switch? any help will be great
thank you all
Old Jul 8, 2011 | 08:10 AM
Sounds like the stoplight switch on the brake pedal assembly or a short in the wiring. The CHMSL is triggered by the stoplight switch. Disconnect the stoplight switch and test for power on both the orange & white wires. There should be +12V to the orange wire, but the white wire should not. If there is +12V on the white wire, there is a short in the system somewhere. While the stoplight switch is disconnected, test for continuity. It should close when the pedal is depressed, but open when not depressed.
It is possible for the multifunction switch to back feed into the stoplight circuit if things were to go really wrong inside.
Old Jul 8, 2011 | 08:17 AM
szls188's Avatar
Thank you for your reply I will check
hope its the switch
CRAZYBLAZER87
Aug 16, 2012 08:50 AM
cory renner
Aug 2, 2012 12:54 PM
Bertbart
Jun 16, 2012 04:53 PM
locoboy72
Oct 19, 2010 12:37 AM
matt92
Sep 29, 2010 12:22 PM
