Brake pads
Brake pads
I just replaced the brake pads and I have a squeaking noise does anyone know what it might be.
RE: Brake pads
you didnt apply stop-squeak to the back of the pads?
RE: Brake pads
I put some grease on that came with it but im not sure if it was the stop squeak
RE: Brake pads
Makes the noise while driving or all the time? Did you replace the hardware too, or just the pad?
RE: Brake pads
I only replaced the pads cause the rotors didn't look bad theirs some occasional loping and it only makes the noise when I come to a stop
RE: Brake pads
Im assuming you put semi-metalic pads on? Or do you even know? And if you feel "loping" thats probably whats causing it. Even the smallest of warp in a rotor can cause it to squeal. Or your hardware is worn and the pads are vibrating. Did you change out the little shims on the end of the pad that holds it in the caliper?
RE: Brake pads
I installed semi-metallic and replaced the shims
RE: Brake pads
i replaced mine with duralast semi metallic pads, and replaced the rotors with duralasts. mine did it to. i am assuming judging from other people i have met with semi metallic pads that they all do it. i am planning on putting on some ceramic pads on my truck. they no longer squeek but the amount of brake dust is outrageous.
RE: Brake pads
Do you think I should install the ceramic pads????
RE: Brake pads
I just did ceramic, and I still have some squeaking.
