brake pedal travel
Old Jul 14, 2013 | 06:33 PM
argon929's Avatar
argon929 is on a distinguished road
Default brake pedal travel
got a 99 4x4 with 156000 on it i have tried searching with no luck i was having problems with my brakes so they got a overhaul new rotors, pads, calipers, master cylinder, brake booster because it was shot the master cylinder was bled before install all brakes where bled after everything was installed but i still have about 3 inches of brake pedal travel before i get brakes is this normal ? thanks
Old Jul 15, 2013 | 07:27 AM
argon929's Avatar
anyone
Old Jul 15, 2013 | 02:23 PM
abig84's Avatar
a lot of people say you need the tech2 scanner for s10s ive done so many and have never needed a scan tool. bleed at the mastercylinder lines first, do both maybe like 6 times or a few times after air stops coming off. then bleed at the abs lines if you can get at them then bleed the backs again then the fronts.
also theres always a chance that some of the brakes are installed incorrectly. rears way out of adjustment or something screwy up front
zach bjorge
Mar 17, 2011 06:49 PM
Spectreblazer
Feb 25, 2010 12:09 PM
king22
Suspension Tech
Sep 25, 2009 04:20 PM
Patrick_Boyle
Apr 6, 2009 08:43 PM
painter
Jun 24, 2007 04:41 PM
