brake problem
Old Feb 28, 2009 | 09:47 AM
dimone545's Avatar
dimone545 is an unknown quantity at this point
Default brake problem
So I was having a problem with my brakes not stopping, I bled them changed pads and nothing worked. So I just decided to replace the power brake booster and the master cylinder in one shot. I have installed it all and it seems to have fixed the problem, my question is what could have caused the back brakes to not bleed correctly now, yet they bled just fine before Ichanged these parts. When I bleed the brakes to try and get the air out of the system in the rear the fluid just dribbles out but before it shot out like a jet... I dont understand why its not bleeding. I capped all the lines when I replaced the booster and m\cylinder so I dont see how it could be clogged by debree. Is there anything else that might be the cause that you guys can think of?
Old Feb 28, 2009 | 10:15 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: brake problem
Did you bleed the master cylinder and is it possible air got into the abs unit. When I had my rear brake lines changed they got air in the abs unit and took most of the day getting it out, luckly they didnt charge me for that since it was there fault.
Old Feb 28, 2009 | 12:21 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
I agree it could be air in the ABS system or you may have a sticking proportioning valve. I had problems with a sticky proportioning valve when doing brakes on my brothers car. I kept flushing new brake fluid through the system but couldn't get all the air out. Once I got his proportioning valve working again everything cleared up(He wouldn't spring for a new proportioning valve)It took me 8 hours to do that brake job & now I won't work on his beaters.
Old Mar 10, 2009 | 12:49 PM
dimone545's Avatar
how do I check the abs and bleed the master cylinder? I thought I just had to bleed from the calipers and drums?
Old Mar 10, 2009 | 07:29 PM
Did you bench bleed the master cylinder prior to installing it? If you did not completely bleed the master cylinder prior to hooking up the brake lines, you have very little chance of properly bleeding the rest of the system. You can bleed the master cylinder with it installed, but it involves removing the brake lines and installing bleeder tubes which run up into the reservoir.
zach bjorge
Mar 17, 2011 06:49 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
