Brake Problem
Brake Problem
Hi everyone. I'm having a problem with the brakes on my 1998 Blazer LT. The brakes go all the way to the floor with little stopping power, and the emergency brake did work but not very well either. There is no grinding noise at all. Would this be a brake line problem? Thanks for your help.
Is the brake master cylinder reservoir full of brake fluid, or has it leaked out? If it is still full, then probably master cylinder has gone bad. If empty, then look elsewhere in the brake system for an external leak.
Salt can be hell on brake lines here in the rust belt.
If you're not used to working on brakes, many insurance policies will cover towing in a case like this and many places will inspect brakes for free. Be safe.
If a brake hose or brake line has failed there will be an obvious external leak of brake fluid. Master cylinder will leak internally.
Correct, but the reservoir is split due to dual hydraulic systems for the brakes (safety feature since 1967). If line or hose is leaking, one side (of reservoir) would go down and eventually be empty (the other would not). Should be able to see brake fluid level through the translucent reservoir.
check the lines going to the rear of the vehicle. They are known for rusting out. They run along the frame on the drivers side. lay on the ground next to the vehicle and have someone push the brakes for you and you should see it leak out. I've had to do those on my K1500 and blazer.
SCBlazer96
04-16-2010 08:39 PM
xderkax
01-14-2010 11:38 PM
Hoelgi
17
10-20-2007 08:49 PM
