brake problems
Old Nov 14, 2011 | 08:31 PM
rogerm's Avatar
rogerm is on a distinguished road
Default brake problems
after replacing my master cylinder (I did bench bleed it) I started bleeding my brakes from rear to front I broke off the bleeder valve on the pass side, at the time my brakes spongey but I had some pedal. So I ended up replacing the pass side caliper and continued bleeding but now I'm getting a constant hissing sound after I the pedal is pushed in, it doesnt go all the way to the floor but makes this noise, any ideas?
Old Nov 14, 2011 | 08:40 PM
Year, make, model, power or manual brakes, with or without ABS? Why was master cylinder replaced?
Old Nov 15, 2011 | 08:29 AM
rogerm's Avatar
98 blazer 4WD, power brakes, I dont think it has ABS (new vehicle to me and I dont know to much about chevys) I replaced the master cyclinder because I kept losing brake pedal slowly until I didnt have any even after bleeding so I figured I needed a new one
Old Nov 15, 2011 | 09:16 AM
rogerm's Avatar
yes I do have ABS
Old Nov 15, 2011 | 10:34 AM
pettyfog's Avatar
When you replace the Master cylinder on an aBS truck, you have to bleed the ABS actuator. Usually job for advanced scan tool. Search to find other options.
But that hiss comes from the Power Brake booster. Was there adjustment screw on the master cylinder pin? If so, must be set at exactly the right height for the application
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
upblazer95
Apr 4, 2009 08:27 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
