brakes
Old Aug 11, 2012 | 01:36 PM
deathrider's Avatar
deathrider is on a distinguished road
have a 2001 chevy blazer when you step on the brakes its like the abs is kicking in like its detacting slipping and its dry outside
have a 1998 blazer the brakes feel sponge no brake leak how do i tell if the master cylinder is bad
Old Feb 8, 2013 | 10:51 AM
scubacamper's Avatar
scubacamper is on a distinguished road
I don't know about your 1st issue but the spongey feel is likely air in your brake lines. If your calipers are good and you don't have a leak anywhere, go through the bleeding process to push the air bubbles out - you may need someone to help you with this.
Rationale: Hydraulic systems work because hydraulic fluid cannot be compressed, while air can (hence, air compressors). When air gets into the system, it makes the pedal feel spongey because the air is able to compress within the line.
Now, if this issue just "appeared", you need to go through the entire braking system to make sure there aren't any leaks at any of the connections. Somehow, air is getting into the line. (If the master cylinder reservoir goes empty, it can suck air).
Old Feb 8, 2013 | 07:12 PM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
My 98' did this until the day I sold it. The ABS sensors are either dirty, or the wires leading to the sensors are corroded. Go to the hubs, and CLEAN THEM! Check the wires, and replace if necessary. If after this, the brakes still give you that sensation when you step on the pedal, go under the hood and pull the ABS relay from the fuse box.
The reason I sold my blazer: I didn't have the money for the new ABS sensors, and I almost caused a 4 car pile-up because I couldn't stop.
Good Luck, and be safe!!! ~Mike
Old Feb 8, 2013 | 07:34 PM
newguy's Avatar
Could also be bad hubs. play causing the issue
Old Feb 8, 2013 | 08:39 PM
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
rnjohnson
Nov 16, 2009 08:39 AM
