Break Fluid Leak/ABS Problem
Old Apr 17, 2013 | 11:24 AM
bassson's Avatar
bassson is on a distinguished road
Default Break Fluid Leak/ABS Problem
So I have a 98 Blazer 4x4.
So i had a rear caliper and master cylinder replaced about half a year ago.
After the replacement I noticed that I was slowly loosing fluid. The front of the master is going down, and the back is fine.
When the front of the master was low, i noticed that the ABS would kick in when going about 5 mph or slower. Now (even after filling master up) ABS is kicking in all the time. I pulled the fuse on ABS because its just annoying.
I checked all the lines in the front of the blazer for break fluid leaks, but couldn't find any visible ones. Could it be a piston in the caliper? (I can smell break fluid burning off after i drive for awhile)
Could the ABS just be a coincidence in timing? I'm planning on replacing the front bearings on both sides in the next month.
also, I have an oil leak coming from the back drivers side of the engine, any suggestions on where that could be leaking from?
-Cheers
Rob
Old Apr 17, 2013 | 01:44 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
The ABS could be related, or it might not be. Have you had codes checked on your vehicle? Between everything you described, it seems like someone did a very shoddy brake job. The calipers are a possible source of the burning smell, but that's not a definite. You need to try isolating the source of the smell. As for ABS malfunctions, bad or damaged wheel speed sensors are a common occurrence.
As for the engine oil, I'd check and see if it's coming from the rear crankshaft bearing - it's a very likely culprit. Have you actually seen where it's coming from, or have you just seen it on the ground?
Old Apr 17, 2013 | 05:37 PM
bassson's Avatar
Thanks for the info!
Just wondering, could the oil leak possibly from the intake manifold gasket? I replaced them about a year ago, but i used a crappy torque wrench. You think the leak could be from the back of that due to poor instillation/not torqued enough? I would much rather redo a manifold job then a rear main seal. lol.
I cant really see the back of the gasket without pulling parts, but I'm just seeing if anyone thinks that its possibly the manifold
Old Jan 2, 2014 | 09:29 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Did you ever solve the problem(s)? Are you sure it is an engine oil leak?
Could be old gooey rusty brake fluid leaking from the rear brake line, which is on the drivers side. Rusts on frame rail just under the firewall. Front reservoir section is for the rear brakes.
ExplicitYourSelf
Aug 12, 2009 02:20 PM
ExplicitYourSelf
Aug 11, 2009 07:38 PM
tekno62
Mar 24, 2009 06:39 PM
XtreeX
May 9, 2007 01:11 PM
tee866
Sep 5, 2006 12:23 AM
