Broken Rod
Its just you're standard white 01 Jimmy SLT nothing special. It doesn't do so hot on straightaways but in the corners it does well. The only fear I have is that fact its so top heavy I am always concerned I will flip the thing
Wait, what?
You're saying your Jimmy does good in corners? What have you done to the suspension? Lowered it, performance springs, and shocks? Heavier sway bars? What kind of tires?
I mean, maybe compared to full size trucks and suvs it handles OK, but my cheap, old Cobalt handles light years better than my blazer
Now, that's not to say that with enough money and time, you can't get a blazer/Jimmy to handle decent. But not in stock form
How do you know the rod broke? Have you taken it apart and inspected it? It doesn't seem to me like you could continue to drive it at 45MPH with a broken rod. Every broken rod I've seen (which is quite a few) has windowed the block and/or tried to exit the side of the oil pan. Is there any chance it's just a spun bearing? That could happen for lots of reasons, including an intake manifold leak.
It take some time to learn and my dad has taught me all his tricks. I have some slightly bigger all terrain tires on it. It hard to describe how to corner with it. Its a big weight game when it comes to the corners like with most cars. I can try to got more into depth on it but it might take some time to collect my thoughts.
Edit: Just learned I spun a bearing but my uncle doesn't want to rebuild he just wanted to drop a new engine in
An engine that is still running with a broken connecting rod? It’s possible if it broke. In the right place at the right time but that’s usually a pretty violent event. Did the mechanic drop the oil pan and look, pull the heads, check compression etc or just listen to a running engine?
i agree with Mike, there may be other options if the failure is limited and the engine is otherwise worthy of repair.
it may come down to labor cost and capability though. If a good replacement engine is available and engine swapping is a core talent then maybe that’s the play
George
George
There is a chance, the mechanic is limited and it's more convenient for him to swap then carry out the repair....
i was editing my post to say the same thing as you were typing. I am after all of Polish decent so like minds ...
George
