Burning smell underhood
Old Feb 25, 2010 | 05:33 PM
Blazerboy1611's Avatar
Blazerboy1611 is on a distinguished road
Default Burning smell underhood
I got a wierd smell under the hood.
Smells like burnt rubber but i dont know if its the belt.
checked the belt; shows no sign of rubbing.
Any ideas?
Old Feb 25, 2010 | 05:39 PM
Take off the lower air dam (what runs from behind the bumper to near the front axle). Look at the passenger side frame rail directly under the radiator for the AIR pump (AIR = air injection reaction which forces fresh air into the exhaust system which is supposed to improve catalytic converter efficiency). Follow the large line out of the AIR pump to where it 'T's off going to either side of the motor. Somewhere after that 'T' there will be rubber elbows. If the check valves fail in the AIR system allowing exhaust gasses into hoses that cannot handle the heat. It may be what you are experiencing.
rocktheguitarist
May 8, 2011 08:25 PM
bumsinthehouse
Apr 22, 2009 12:21 AM
Rp9110
Mar 3, 2008 06:30 PM
aced411
Dec 22, 2007 02:16 PM
KLBlazer07
Mar 11, 2007 05:44 PM
