A/C Clutch
I have 2 questions
1) I need to change the clutch on my A/C compressor, I cannot get the tool for holding the clutch so that I can get the nut off that holds it. is there another way to get this done?
2) my manual does not show it but I understand I need to space an area where the clutch ingages, but I do not know how much space is needed ??
thanks for any help
thanks for any help
If you are replacing the clutch with a new one, then any means necessary to lock the clutch and get the nut off is available and that includes means that may damage what you are replacing.
I believe I have always used an impact gun to get things apart. The nut shouldn't be all that tight.
On reassembly, I have always installed the belt then locked the clutch by applying power to it then tighten with a rachet.
MintyMadness
Jul 13, 2011 12:37 AM
speedfreak81
Oct 13, 2009 06:58 AM
Plage50
Jun 6, 2007 09:00 AM
