A/C Clutch
Old Jan 6, 2007 | 01:04 AM
ron36535's Avatar
ron36535 is an unknown quantity at this point
Default A/C Clutch
I have 2 questions
1) I need to change the clutch on my A/C compressor, I cannot get the tool for holding the clutch so that I can get the nut off that holds it. is there another way to get this done?
2) my manual does not show it but I understand I need to space an area where the clutch ingages, but I do not know how much space is needed ??
thanks for any help
Old Jan 6, 2007 | 01:24 AM
Chevy Lover's Avatar
Default RE: A/C Clutch
I have no idea how you can even remove the compressor clutch without special tools.
I can't find specs for the gap on the plate, but I think it's about .020"
Sorry I can't help.
Old Jan 6, 2007 | 01:35 AM
If you are replacing the clutch with a new one, then any means necessary to lock the clutch and get the nut off is available and that includes means that may damage what you are replacing.
I believe I have always used an impact gun to get things apart. The nut shouldn't be all that tight.
On reassembly, I have always installed the belt then locked the clutch by applying power to it then tighten with a rachet.
MintyMadness
Jul 13, 2011 12:37 AM
speedfreak81
Oct 13, 2009 06:58 AM
Red03
Sep 25, 2008 08:37 PM
Plage50
Jun 6, 2007 09:00 AM
m00nwater
May 18, 2005 09:27 AM
