A/C clutch not engaging
Old Sep 21, 2011 | 09:39 PM
ExpressEN1's Avatar
ExpressEN1 is on a distinguished road
Default A/C clutch not engaging 99 Blazer LS
OK, I hate to ask but, the other day I found a post that listed several switches/sensors that affect the ac clutch. Tonight, I can't seem to find it again. Aside from the low and high pressure switches, what other switches or sensors would stop power from getting to the clutch on a 99 Blazer. I have already checked the relays and fuses.
Thanks in advance
Old Sep 23, 2011 | 11:20 PM
ExpressEN1's Avatar
Question
come on, no ideas?
Old Sep 24, 2011 | 12:23 AM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
dude
you need to give time for answers. this isn't a professional help site
Old Sep 24, 2011 | 07:29 AM
The HVAC control module is the only other thing that controls the A/C clutch aside from the high & low side switches & relays/fuses.
Old Sep 24, 2011 | 09:45 AM
ExpressEN1's Avatar
Thank you for the info.
Old Oct 15, 2011 | 01:47 PM
ExpressEN1's Avatar
Well, after scratching my and and pulling my hair out, I found the problem with my a/c. Most of the contacts in the power center under the hood are corroded. I cut up a couple of emery boards and cleaned all the contacts. I am happy to say "my a/c works again".
Old Oct 16, 2011 | 03:18 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Man that was lucky, I was going to make sure you put enuff freeon in it lol. And I know 'freeon' isnt spelled like thats lol. Because to much and not enuff both can cause this problem.
Old Oct 16, 2011 | 06:04 PM
pettyfog's Avatar
Well... for posterity..and future readers.... DONT DO THAT!
First thing you check is one at a time, you jumper the connector on the Accum.. then the Hi press switch.
- If jumping accum switch does it, you feel line going into accum, then compressor to see if they get cold.
If line into compressor gets cold then it's bad switch on accum.
Doing that simple test will prevent dumping in too much freaon
seriosbrad
Nov 7, 2015 09:08 PM
MintyMadness
Jul 13, 2011 12:37 AM
gscrippler
Mar 14, 2011 06:37 PM
chrisblaze
Dec 6, 2009 12:27 AM
Red03
Sep 25, 2008 08:37 PM
