A/C Clutch Problem
Okay, i spent some time with my multi-meter and this wiring. Here is what I found:
Ohm check:
Low Pressure Switch - closed
High pressure switch - open
Blue wire from high side to relay - good
white wire from low side to relay - good
black wire from relay to clutch - good
green wire coming into high side plug - do not know where it comes from. it is melted and burned in the plug. there is a green wire to each plug, so I am assuming it is a common wire between them.
So, is the high side switch bad or is there too much pressure in the system? I can tell that I need to replace the plug since it is broken and burned/melted.
I also checked the relay, and the circuit from 30 to 87a (N/C) is good, and 85 to 86 (N/C) is good. 30 to 87 (N/O) is open like it should be. So, is there any other fuse in this circuit that may have caused the clutch to work once when I jumped the high side connector and then not again? Or, is the plug so messed up that it just will not work right (my guess right now)?
Thanks for all of your help.
Brian
Ohm check:
Brian
MintyMadness
07-13-2011 12:37 AM
dankin831
07-20-2010 12:01 AM
