A/C compressor issue
Old Jan 27, 2013 | 09:08 AM
Windwing1967's Avatar
Windwing1967 is on a distinguished road
Default A/C compressor issue
My compressor keeps clicking on then off (for about 1 sec.) it keeps doing this about every 10-15 second intervals. I don't Ned air right now since it is winter. Can I disconnect wire harness temporarily until I have time to diagnose is the spring?
Old Jan 27, 2013 | 12:57 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Pretty sure thats normaly how an AC clutch works, cuts in and out unless you hav AC on it stays on.
Old Jan 28, 2013 | 06:54 AM
Default Ac
Thanks, I didn't know that. But should it be noisy? I can hear it clicking on and off, it's kinda loud.
Old Jan 28, 2013 | 07:05 AM
Rapid on/off cycling of the clutch indicates a low refrigerant charge and is not normal operation.
Even in the winter, the AC is used to remove moisture from the air inside the vehicle when using any of the windshield defrost modes.
If you are low on refrigerant, it may just need a can or two to top it back off. But if you would rather wait for warmer weather to inspect and repair, you can just disconnect the clutch wiring.
Old Mar 7, 2013 | 07:09 PM
6blue22's Avatar
6blue22 is on a distinguished road
there is a low-pressure sensor on the accumulator--the compressor is likely cycling off due to a loss of refrigerant . . . if you disconnect the electrical connection to the sensor, the compressor will not run . . . you probably have a leak somewhere, hence the low pressure
Chic_Bowdrie
Jun 21, 2014 12:23 PM
MThompson
May 30, 2014 01:19 PM
mexlokote
May 6, 2012 01:25 AM
gmcjimmy_94
Dec 30, 2010 12:37 AM
BresBlazy
Aug 28, 2010 10:08 PM
