A/C Compressor Won't Engage - 1999 Blazer
Old May 25, 2019 | 04:36 PM
mickey_bigdaddy's Avatar
mickey_bigdaddy is on a distinguished road
So does replacing the pressure switches on the AC system require removal of the refrigerant? I have a 1999 GM service manual and it makes no note of doing that for the High-Pressure Cut-Out Switch nor for the Pressure Cycling Switch. However for other AC service, such a hose replacement the manual will (not surprisingly) mention recovering all of the refrigerant.
Well there isn’t a schrader valve on the compressor. The high pressure switch is installed with an o-ring directly into the socket on back of the compressor and secured with a snap ring. In the socket, there is a hole on the compressor which I assume Freon/oil flows by so that the high pressure switch can read the pressures. When you remove the high pressure switch on a working system, there is oil in that socket so I assume the system is exposed/opened if that switch is removed. I took my Freon out before I took off the compressor so I am not 100% sure.
Old Jul 19, 2019 | 08:35 AM
jrm000kc's Avatar
jrm000kc is on a distinguished road
I found out the hard way that yes, you need to evacuate your system before pulling the one on the back of the compressor. (After the guy at the parts store said I didn't.)
mharrison
Aug 27, 2019 01:23 PM
jrm000kc
Jul 22, 2019 06:01 PM
chevybaby97
Jul 23, 2011 04:48 PM
frodiggs
May 3, 2011 10:33 PM
joey
Aug 8, 2007 12:37 PM
