a/c doesnt blow cold
Old May 29, 2012 | 09:13 PM
ctyler's Avatar
ctyler is on a distinguished road
If that doesn't work you need a set of gauges on it. Look at the low side pressure when the compressor is engaged. The pressure will drop when the compressor engages. If it drops to about 20lbs the compressor will disengage due to low pressure. I.E. you need more refridgerant. I charge all mine to roughly 40lbs.
If the pressure is good on the low side the you need to look at the high side.
Things are not always straight forward at this point but... If the pressures are both about the same pressure the compressor may be done or something is plugged. Let us know what you see of it gets this far.
Old May 30, 2012 | 08:21 AM
fmedina's Avatar
fmedina is on a distinguished road
ok thanks. ill start troubleshooting maybe later today after work or tomorrow. I have a test gauge but where is the low pressure valve at. I see the high pressure one
Old May 30, 2012 | 08:24 AM
fmedina's Avatar
Originally Posted by 50lb_cat
Ususally short cycling meens low freon. However, if you are sure it has the proper charge it could be a bad pressure switch. Try disconnecting the battery to reset everything first. Sometimes it works. Before buying a new compressor I would swap out the pressure switch though.
which pressure switch tho
Old May 30, 2012 | 09:46 AM
50lb_cat's Avatar
Its the low pressure cut off switch. The low pressure port is on the accumulator ( the large metal can). Always fill from the low side port!
Old May 31, 2012 | 06:28 AM
fmedina's Avatar
alright thanks. I still haven't had the time to do anything but ill keep you guys posted
bobby099
Dec 22, 2018 09:41 PM
kmartin
Jan 13, 2014 05:41 AM
delete242001
Apr 2, 2009 06:58 PM
99blazingred
Aug 23, 2005 10:53 PM
jimmyone
Jan 27, 2005 06:32 PM
