A/C Drain Problem!
Old May 6, 2013 | 09:09 AM
Blues15's Avatar
Blues15 is on a distinguished road
Default A/C Drain Problem!
Vehicle Info: 01 Chevrolet Blazer LS 2wd 4dr stock 59,000
Floor board is wet after having the a/c on for a while, its NOT antifreeze i know that. Anybody else have this problem? Searched but could not find anything.
Old May 6, 2013 | 01:04 PM
abig84's Avatar
alot of vehicle's drains get clogged with leaves and dirt over time, you basically just have to find it and unclog it, sometimes you can just stick a small screw driver in there and knock it out other times compressed air will work
Old May 6, 2013 | 03:21 PM
Blues15's Avatar
That's the problem, i can't find the drain for the a/c. Any idea of where to look at? Will i have to pull the inner fender out?
Old May 6, 2013 | 04:13 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
I believe the drain is on the passenger side front under where ac lines go into a black housing on the inside of the frame (engine side). But i don't know the exact location. I know its been covered on here, so if you search something like "ac drain" or "ac fluid drain" you might find something. Or PM CaptainHook because he knows.
Old May 9, 2013 | 01:25 PM
abig84's Avatar
Originally Posted by 97cherryblazer
I believe the drain is on the passenger side front under where ac lines go into a black housing on the inside of the frame (engine side). But i don't know the exact location. .
yeah im about in the same boat. they are always on the passenger side near the firewall. sometimes theres just a little hole other times you will see a hose, they are all different depending on make and model. try googling around see if anyone has up a picture somewhere
Old May 12, 2013 | 10:11 PM
Blues15's Avatar
A little late posting but I found my problem, a wire grommet fell out just beneath the drain hole and that's how water was getting inside. I took a pic of how the drain hole looked. I just removed the wheel and removed just enough bolts on the inner fender to get my hand in there to clean the drain hole.
The drain hole is in the center of the pic
Attached Thumbnails A/C Drain Problem!-imag0314.jpg
radiorara
Aug 21, 2011 08:38 PM
masterchf117
May 2, 2010 02:18 PM
luvastyl
Apr 19, 2010 11:20 PM
FLcruising
Jul 4, 2005 02:51 PM
2001Blazer4x4
Mar 2, 2005 10:45 PM
