A/C hardly blows at part throttle
Old Aug 30, 2009 | 06:07 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Default A/C hardly blows at part throttle
The air blows fine until I give it ~50% throttle or more, then it barely blows from the vents. Manual A/C...I found the red and blue vac lines from the control module(with the ***** on it) by the BCM. They go into a distribution block, of sorts, with two empty ports on the other side. Anyone know what's suppose to go in those empty ports. I can take a pic if needed. Thanks.
Old Aug 30, 2009 | 06:15 PM
You have a problem with the vacuum supply from the engine to the HVAC controls. The vacuum reservoir is located in (as in inside) the driver side fender up near the firewall. If this is disconnected, it can cause this problem.
Old Aug 31, 2009 | 06:53 AM
Vac res is still connected. This problem appeared after I swapped bcm's for keyless entry, so I was sure I pulled something loose behind the dash. Finding the red and blue vac lines not attached to anything sort confirmed that. Looks like I'll be pulling it all apart again this afternoon.
Old Aug 31, 2009 | 07:19 AM
That would definitely do it! I have posted the vacuum diagram for these trucks somewhere...
Doug A.
Oct 12, 2015 03:23 PM
spider21
Nov 17, 2011 06:27 PM
abig84
Oct 19, 2009 10:57 PM
BOTTLEDZ28
Dec 3, 2007 08:18 AM
BlazinFire
Aug 6, 2005 01:51 AM
