a/c heater problem
Old Jun 21, 2010 | 01:28 PM
micker's Avatar
micker is on a distinguished road
Default a/c heater problem
when i start the engine the a/c works fine when i start down the road it goes to heat i replaced the vacuum lines from the manifold to the vac reservoir the vac check valve is working the vac pots all work even going down the road
Old Jun 21, 2010 | 03:11 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Does it go to heat or does blow out warmer air? Sounds similar to what mine was doing and it was due to the air gap in the compressor clutch being out of adjustment.
Old Jun 22, 2010 | 10:01 AM
micker's Avatar
do you know what the spec for the gap is thanks
Old Jun 22, 2010 | 10:03 AM
micker's Avatar
feels like heat i will put a thermometer in the duct and take a test drive
walkingtall
Feb 26, 2009 09:28 PM
Chris438
Nov 17, 2006 03:28 AM
2003blazer
Dec 30, 2005 12:21 AM
newblazer22
Dec 20, 2005 09:01 PM
Jorgen
Nov 28, 2005 11:42 AM
