a/c help
Old Jun 11, 2011 | 11:05 AM
colesdaddy02's Avatar
colesdaddy02 is on a distinguished road
Default a/c help
2000 blazer 4x4x4. Does anyone know if you can change the high pressure port valve or do you have to change the whole tube? I have a leak that is coming from the little black ball in the valve.
Old Jun 14, 2011 | 07:37 PM
ctyler's Avatar
ctyler is on a distinguished road
Yes, you can change the schrader valve inside the port on both the high and the low side. Looks like a large tire valve core. You'll need a special tool to change it without dumping the charge in the system. The tool is about $40 on up each.
It may just need to be tightened a little, you can get a tool for that for 5-10 bucks.
