A/C Leaking out low service port
Old Mar 9, 2019 | 06:42 PM
RedBlezer's Avatar
RedBlezer is on a distinguished road
Default A/C Leaking out low service port
Bought my blazer with 185k on it, a/c never worked. Summers comjng up so I just tried to charge it, and aside from the compressor kicking on and eating up the pressure and then dying, it wants to leak all the a/c pressure out of the low pressure service port. As soon as I pull the hose off it leaks.
Is this a common issue? Indicitive of anything? If I leave the hose attachment and a/c recharge can on it works fine. Would leave it all hooked up but the can would probably explode w all that heat.
Old Mar 9, 2019 | 08:04 PM
odat's Avatar
It has a shrader valve in it just like your tire valve stem has. They change out and your auto parts store should have them.
Old Mar 9, 2019 | 09:11 PM
RedBlezer's Avatar
Ok sweet. Ill buy a few more ac cans and swap that out
Old May 31, 2019 | 05:22 PM
RedBlezer's Avatar
Replaced shrader for $8. Recharged and works no problem. Took 2 cans of redtek
Old May 31, 2019 | 10:03 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
If you dropped the charge to change the schrader core I hope you put a vacuum pump on the system to remove air and moisture before recharging.
Old May 31, 2019 | 10:42 PM
RedBlezer's Avatar
What would the consequences be if I didn’t?
Old May 31, 2019 | 10:50 PM
GeorgeLG's Avatar
Old Jun 1, 2019 | 01:27 PM
G0LFADD1CT's Avatar
Air gets trapped at the top of the condenser coil causing the head pressure to climb, which lowers the cooling capacity. Moisture will mix with the oil and eventually start forming acid which will damage a lot of internal parts (especially that expensive compressor).
Old Jun 1, 2019 | 02:10 PM
odat's Avatar
Nobody is going to agree with me But ---- If you had any pressure at all left in the system and if you didn't loly gag around changing the valve out you should be fine ---- The leftover vapors will actually still work its way out and slow any air contamination --- There is more air in a home fill kit's hose than you let get in changing the valve ---- changing out major parts as compressors or having the system wide open is when problems begin without a vacuum pull ....
Old Jun 2, 2019 | 09:22 AM
I agree with you. In fact, I was about to say the same thing. The chances of any moisture entering through the service valve in the one minute the core was out are extremely slim.
