A/C line problem
Old Jun 17, 2018 | 07:45 PM
Hopej's Avatar
Hopej is on a distinguished road
Default A/C line problem
A/C lines had a leak so replaced them added dye and charged worked great for a weak then noticed blowing warm checked lines leaking again anyone have any problems with lines getting holes or leaking
Old Jun 17, 2018 | 10:09 PM
GeorgeLG's Avatar
Where is the new leak?
George
Old Jun 18, 2018 | 06:14 AM
Hopej's Avatar
I looks like it is in same spot where the two lines curve over radiator hose by airbox
Old Jun 18, 2018 | 08:16 AM
GeorgeLG's Avatar
So you had a leak in the body of an AC refrigerant line, replaced it with a new line and the new one also leaks in the body (between the connection points) in the same place? How do you know that the line is leaking?
George
Old Jun 18, 2018 | 09:30 AM
Hopej's Avatar
I'm gonna rinse off all areas and shoot a little freon with some more due in it and watch to see where it comes out exactly
Old Jun 18, 2018 | 11:04 AM
GeorgeLG's Avatar
Look for oil residue before you rinse it off. It comes out with the 134a refrigerant.
George
Old Jun 18, 2018 | 11:59 AM
Hopej's Avatar
I see oil residue but its blown every where in that location
Old Jun 19, 2018 | 11:05 AM
GeorgeLG's Avatar
That's extraordinary that a rubber refrigerant line failed and a new one failed in the same location. Is the compressor pulley rubbing on the line?
George
Old Jun 19, 2018 | 11:30 AM
Hopej's Avatar
No it's not rubbing the compressor at all
Old Jun 19, 2018 | 11:36 AM
GeorgeLG's Avatar
Do you have access to a refrigerant leak detector to confirm what is happening here?
George
