a/c not blowing cold
Old Feb 16, 2008 | 11:06 PM
formervictim's Avatar
formervictim is an unknown quantity at this point
Default a/c not blowing cold
i have a 2000 blazer 4.3 vortec. a/c won't get cold. compressor doesn't make any unusual noise. checked the "charge" it was low. i used a can of refridgerant, still no cold air. checked later, charge was low again. where do i start troubleshooting? any tips would help alot. thanx.
Old Feb 16, 2008 | 11:42 PM
thegr81's Avatar
Default RE: a/c not blowing cold
Take and get the U.V. kit at the parts store put that in the system and then following the directions check for leaks!! The kit comes with a special light and glasses for tracking down leaks.
Old Feb 21, 2008 | 11:00 AM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
The compressor will only run about 5 seconds at a time until it has enough gas pressure in the system.
Old Feb 21, 2008 | 03:32 PM
kerander's Avatar
kerander is an unknown quantity at this point
Yeah, and if it's leaking, it's leaking oil with it because the refrigerant and the oil are miscible. So you might not have enough oil in there as well. Might be time to take that system apart for a good cleaning, flush, new o-rings, etc. if you want to do it right. Oh, and if you do you HAVE to vacuum the system down before filling, unless you want to replace the whole system soonafter.
Old Feb 21, 2008 | 03:35 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
have your whole system evacuated!!! and refilled properly..
96blazen
Jul 15, 2014 05:25 PM
TEALBlazer
May 12, 2011 06:12 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
stevenson_ltdan
Jan 22, 2008 05:47 PM
