C0269 - Excessive Dump/Isolation Time???
Old Jan 7, 2010 | 05:01 PM
smitty1244's Avatar
smitty1244 is on a distinguished road
Default C0269 - Excessive Dump/Isolation Time???
I looked all over i cant find out what this code means C0269 - Excessive Dump/Isolation Time Please help Thanks rob
Old Jan 7, 2010 | 05:29 PM
C0269/C0274 - Excessive Dump/Isolation Time
The most likely cause of DTC C0269 or DTC C0274 is a mechanical failure that causes a wheel to lock and remain locked. The DTC(s) may also be set, conceivably, by activating the ABS on surfaces that are nearly impossible to get traction on (i.e.; sheet ice). In either of these situations, diagnosis of the ABS system is not necessary.
Sadly, most of the diagnostic sheet requires a Tech2 or equivalent scan tool to push the EBCM through some tests.
NCRD1331
May 22, 2013 12:55 PM
BigEffingHammer
17
Jul 18, 2012 08:51 PM
kiwiblazer
Jan 11, 2012 10:36 PM
walleye seeker
Sep 1, 2010 09:52 PM
