Cam/crank pos. Code
What DTC's are you retrieving? What symptoms are you having?
Whenever the crankshaft position sensor and/or timing cover is moved, removed, replaced, or disturbed in any way, the crankshaft position sensor relearn MUST be performed with a scan tool capable of initiating the relearn.
what dtc's are you retrieving? What symptoms are you having?
Whenever the crankshaft position sensor and/or timing cover is moved, removed, replaced, or disturbed in any way, the crankshaft position sensor relearn must be performed with a scan tool capable of initiating the relearn.
Firstly, I'd inspect the distributor for wear, in the bushing and in the distributor gear. I'd also check to make sure your timing marks are right on Cylinder #1 TDC compression.
That codes indicates that the sensors are out of sync. This means the timing could be off (more than likely), and/or as Hook mentioned you will need a relearn process.
I agree, P1345 means the distributor is off at least one tooth. After you get the distributor installed correctly, you'll need a scan tool capable of viewing camshaft retard data stream to check and adjust it. The same scan tool that can view camshaft retard, most likely can also do the crankshaft position sensor relearn. This will require a "high end" scan tool, the ones that the auto parts stores have are not capable of either, so you'll probably have to take it to a shop with a technician that is familiar with both procedures.
GolfClapperX
Apr 4, 2012 06:51 PM
GM hater
Jan 9, 2010 02:32 PM
