My POS Blazer Won't Turn Over in the Rain
Old May 17, 2006 | 03:09 PM
PawNtheSandman's Avatar
PawNtheSandman is an unknown quantity at this point
Default My POS Blazer Won't Turn Over in the Rain
My 98 POS Blazer:
This week's problem:
Car won't start.
Battery is new, plugs, wires are all new.
Car has power, but doesn't turn over.
You hear it try to start, but never fully turns at the end.
Won't start in the rain or after it rained.
What could be the problem? Starter? Wires??
Old May 17, 2006 | 04:03 PM
hillbillyinOhio's Avatar
Default RE: My POS Blazer Won't Turn Over
could be the battery cables, I had a bad ground on mine and it wouldn't start, just make sure the cables are tight, and make sure that the plastic on the terminal end isn't stopping you from getting good connections. I just cut mine off.
Old May 17, 2006 | 05:25 PM
MCas86's Avatar
MCas86 is an unknown quantity at this point
this was happening to my buddies jetta...there was just corrosion on the terminals...take a wire brush to it and see if itll start, then let us know how it went
Old May 17, 2006 | 06:10 PM
battery is new.
Terminals are clean, make contact.
Old May 17, 2006 | 06:12 PM
MCas86's Avatar
possibly the starter?
Old May 17, 2006 | 07:45 PM
jagblazer01's Avatar
ORIGINAL: MCas86
^^thats a good possibility, also im not sure but maybe check the alternator. again im not positive on that
Old May 17, 2006 | 09:30 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
probably the starter. I don't think the alternator would make it not turn over unless the alternator didn't charge the battery, causing the battery to run out of juice.
Old May 18, 2006 | 02:18 AM
MCas86's Avatar
yea it cant be the alternator because he said its a new battery, in which case the alternator hasnt even had a chance to try to charge it...seein how its never been started with it..anyways, id say its the starter
Old May 25, 2006 | 02:10 PM
VRDriver4l's Avatar
VRDriver4l is an unknown quantity at this point
Id say starter also, the best alternator test is when the car is running disconect the battery if it stays running the alternator is good if it shuts of go to the part store and get a alternator, im sure most people know that though.
Old May 25, 2006 | 04:42 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Ok I dont say starter... all you need to start the car... power, spark and FUEL. ARE YOU GETTING FUEL??? If not, FUEL PUMP.
Thats my thought... if it cranks fine and no fuel... well, thats just my thought.
