camshaft sensor
Old Dec 18, 2007 | 03:59 PM
rob2129us's Avatar
rob2129us is an unknown quantity at this point
Default camshaft sensor
I have a 2000 blazer and i am wondering what the camshaft sensor does? And can this be tested anywhere "ie parts america" thanks Rob
Old Dec 19, 2007 | 01:26 AM
Chevy Lover's Avatar
Default RE: camshaft sensor
The camshaft position (CMP) sensor is located within the distributor. The operation of the CMP sensor is very similar to the crankshaft position (CKP) sensor. The CMP sensor will provide one pulse per camshaft revolution (1X signal). The loss of this signal may not affect the driveability of the vehicle, but will affect the type of control the VCM has on the fuel injection system. If this signal is lost, the VCM will pulse the injectors bank to bank instead of each individual injector at a time. The VCM also utilizes this signal in conjunction with the crankshaft position in order to determine which cylinders are misfiring
What is the problem you're experiencing and why do you suspect the cam sensor?
I don't know that the sensor can be tested other than with a scanner connected to the data link with the engine running.
Old Dec 19, 2007 | 10:03 AM
rob2129us's Avatar
the reason i am thinking maybe somethinf is wrong with the camshaft sensor is i have 60lbs of fuel pressure at the schrader valve and great spark but no start. Can i open the throttle body and be able to see gas ? thanks
russ1609
Jan 30, 2012 07:08 PM
fox59
Jul 7, 2011 11:38 AM
bulletuga
Jul 26, 2010 08:26 PM
murfthesurf4
Nov 26, 2007 11:00 AM
88blackzcand95blazer
Jan 26, 2007 04:36 PM
