Can you help me shut it up & work right???
Old Sep 13, 2008 | 05:27 PM
Patty's Avatar
Patty is an unknown quantity at this point
Default Can you help me shut it up & work right???
[sm=dontgetit.gif]Hey guys,
I'm just lost on what to do here & maybe one you car guys can help me. I have a 2000 Trailblazer, & the factory alarm keeps going off. Its gone off in the middle of the night, &at work.....lights horn and all....I don't know what to do. Is there something I need to reset? Or maybeI need to replace a sensor......its really embarrassing for a girl to have to run out to turn it off all the time. I've been leaving my doors unlocked for a few days now & I'm starting to get nervous doingthe such. Can someone give me a sugguestion???[sm=feedback.gif]
Old Sep 13, 2008 | 05:40 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Can you help me shut it up & work right???
are you sure someoneisnt playing games with you by kicking your tire and setting off the motion sensor? also do you have a pin sensor under the hood for when that gets opened it would set off the alarm, theres a chance that it may need to be adjusted..it could be sumtin real simple or it could be a malfunctioning alarm box.. How old is the alarm? also if you have your keys with fob in your pocket or where ever it could be getting pressed and the panic is setting it off..
Old Sep 13, 2008 | 05:54 PM
Patty's Avatar
Ummm what is FOB? And no, no one is setting it off.......its a 2000 Trailblazer. It has the Factory alarm....no motion, just door openings& glass breakage will set it off.
Old Sep 13, 2008 | 08:03 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
The fob is the thing on your keychain with buttons on it to lock & unlock your doors...
Old Sep 13, 2008 | 10:15 PM
NVANZEE's Avatar
it probably has a bad door sensor. My dads 98 bravada had that problem
Old Sep 14, 2008 | 07:13 PM
SilverTalon's Avatar
SilverTalon is an unknown quantity at this point
You might also want to have your battery checked for power. My aftermarket alarm started doing that randomly and it wasn't long after that when I noticed my battery was in need of replacement. You can take down to a parts store like Advanced Auto or AutoZone ect. and they can check it for free and be sure to let them know what is going on. Have them check the actual voltage when it's not running, voltage drop when starting the motor, and the voltage at the battery while it's running. The last part of that simply makes sure that the alternator is still working properly and not putting out too much voltage.
Old Sep 14, 2008 | 10:58 PM
Patty's Avatar
[sm=dontgetit.gif] My driver side door also doesn't lock when rolling when I push the lock button on door. My battery is fairly new. The only other thing I can think of is that I had new door speakers put in a few months ago. Could it be the battery on the FOB? I have never changed it.
Old Sep 14, 2008 | 11:08 PM
Patty's Avatar
My 2000 trailblazer has a re-built tranny 3yrs ago, new exhaust, fuel pump inside tank fixed and I need a heater core. No hot heat only enuff to defrost windows. I atleast have heated seats. I think it's time for dinamite.[sm=jawdrop.gif]
Old Sep 18, 2008 | 05:36 AM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
theres a car where i work that the alarm goes off at the same time every day but she says it only happens at my place of work, its an acura RL i think we both think theres a radio frequency that is givin off by the place just my .02
Old Sep 18, 2008 | 08:15 PM
Flea323's Avatar
Flea323 is an unknown quantity at this point
If you did have new door speakers put in the front, there may be a wire that got pinched or they may have crossed two wires somewhere. It may also help us to know where you may have taken it to have the speakers put in.
