Can't connect to OBD port / unknown engine bay connector
Old May 16, 2013 | 08:09 PM
billfrank85's Avatar
billfrank85 is on a distinguished road
Default Can't connect to OBD port / unknown engine bay connector
I was able to connect a scan tool to my 2001 Bravada about two weeks ago. Since then, the only thing I have done is replaced both front wheel bearing/hub assemblies. Now I can't connect, and I've used 3 different scan tools. All my fuses are intact (including the cigar lighter fuse) and I'm unsure where else to look. I was checking my transmission fluid today and found this connector but could not see anywhere within reach, a place to plug it in.
That is the passenger side rear corner of the engine compartment. Any ideas what that is for or if it is related to my OBD port issues? Thanks!
Attached Thumbnails Can't connect to OBD port / unknown engine bay connector-ys36rv4.jpg
Old May 16, 2013 | 10:28 PM
Twip's Avatar
it may not be something that was being used. does the inside of the plug look clean, or all dirty and oxidized? if its the latter, then it probably was an extra. i cant see it causing a problem with the OBD II port.
Old May 16, 2013 | 11:36 PM
Plug is clean, no dirt or anything.
Old Jun 21, 2013 | 12:32 PM
I still can't connect to my OBD port. The cigarette lighter doesn't work but my fuse in the panel next to the steering wheel is good. Are there any other fuses or relays that are on this circuit?
Old Jun 21, 2013 | 01:29 PM
newguy's Avatar
Under the hood is a 20 amp fuse, I think number 13, check that. If not try jiggling the key in the on position while the obd is connected
Old Jun 21, 2013 | 02:18 PM
coolasice's Avatar
coolasice will become famous soon enough
looks like the air pump relay plug...does your sec. air inj. pump work? if not thats probably the reason.... should be a plug to match on the side of the pcm.... just a guess
Old Jun 21, 2013 | 06:18 PM
At the data link connector, under the instrument panel, pin #16 should have an orange wire and it must have battery voltage at all times. It gets voltage from fuse #2 in the instrument panel fuse box. The black wire on pin #4 must show less than 5 ohms resistance to ground at all times. The black with white trace wire in pin #5 must also show less than 5 ohms resistance to ground at all times.
Old Jul 18, 2013 | 07:59 PM
I checked the wiring behind the OBD port, resistance, and voltage on those wires and they are good/intact. I'm running out of ideas. I'm pretty sure this code is causing my Bravada to run like crap and I can't get the port to work to find out what it is.
JasonGoneFishing
May 11, 2024 08:52 AM
alpinesubs
Aug 14, 2012 09:52 AM
pkrawetz
Oct 1, 2009 10:38 PM
hannibaldeschain
Jul 30, 2007 09:13 PM
rodman1369
Jul 29, 2007 03:57 AM
