Cant get right
Old May 19, 2012 | 07:33 PM
01LtBlAzEr's Avatar
01LtBlAzEr is on a distinguished road
Default Cant get right
I have an 01 LT Blazer 4x4, I'm getting the famous P0300 and P0420 codes even after changing my cap, rotor, wires, and plugs. All AC Delco. I cleaned my EGR and MAF just like the DIY told me. I have to crank it for a few seconds just to get it to start and then it has a rough idle, some black smoke if I rev it up, and smells bad. When it shifts between 1st and 2nd, and when accelerating to pass somebody, it sputters as if I'm hitting the rev limiter. Can anyone help???
Old May 19, 2012 | 08:56 PM
50lb_cat's Avatar
Sounds like a bad cat for starters. Then since you replaced everything else I would suspect a worn out distributor or bad coil. Check the rortor to make sure it isn't arching, new parts can fail. Could also be the throttle position sensor.
Old May 19, 2012 | 09:43 PM
01LtBlAzEr's Avatar
If it was a bad coil or distributor would my plugs be fouled out? They didn't look bad at all when I changed them today.
Old May 19, 2012 | 10:30 PM
50lb_cat's Avatar
not nesessarily. My gears were worn on my dist. I ordered a skip white unit off ebay, came with the cap and rotor. Took care of my misfire issues after I already replaced the same items you did. It came with accel parts, I swaped em for my delcos though. I did a review of it awhile ago. I was impressed with the distributor, all aluminum instead of plastic.
Old May 19, 2012 | 10:33 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
I agree with it being a bad cat. Possibly a dying fuel pump, also.
Old May 20, 2012 | 12:11 AM
50lb_cat's Avatar
+1, wouldn't hurt to do a fuel pressure and leakdown test just to rule out the possibility. Autozone has em that you put a deposit down then get it back when you are done.
Old May 20, 2012 | 07:21 AM
Or pay 40 for the cheap one and keep it for next time. Because there will be a next time, especially if you have an Airtex pump.
Old May 21, 2012 | 09:01 PM
01LtBlAzEr's Avatar
I'm gonna try to test the fuel pressure. I'm worried it might just be that damn Airtex pump. I do remember that about 2 weeks after I installed the pump is when I was having trouble starting...
Old May 21, 2012 | 09:10 PM
50lb_cat's Avatar
Ahh, I would be willing to bet its the pump. Stick with delphi or delco. airtex is garbage.
Old May 23, 2012 | 10:44 PM
scoobytuff's Avatar
scoobytuff is on a distinguished road
I've bought a couple of OEM pumps from a guy called "Mr Fuel Pump" on Ebay. They were priced right. It's worth looking into if you go that route.
