cant get this to run right can someone help?
I have only had the truck a couple of months its a 1995 chevy blazer. All of a sudden it would act like it wasnt getting any gas and act like it was going to stall out. if you hit the gas takes a min and catches and takes off for a few but still spits and sputters. Once it dies you cant turn it back over for awhile. We changed out the fuel filter, the plugs and the coil. I dont know what it is... i know the fuel pressure is at 58psi. i was told maybe the injector.. and does anyone know what the ohms reading for a normal injector should be at?
What was the pressure leak down after the pump shut off? CPI engines are notorious for fuel leaks inside the engine.
mr_smith
01-29-2012 01:21 PM
mudcat
20
05-04-2011 05:47 AM
strong blazer
06-21-2008 08:06 PM
