Can't locate Blower Motor Resistor on 1998 Blazer 4x4
Old Jan 11, 2012 | 08:21 AM
Jimmy91's Avatar
Jimmy91 is on a distinguished road
Default Can't locate Blower Motor Resistor on 1998 Blazer 4x4
Help please, the manual states that teh blower motor resistor is on the firewal to the right of the blower motor...we seen the 'cut here' and opened up the space where the resistor is to be but it is not a resistor.
There is another similar looking part but it is not the same connector.
Parts desk said we had the right part #
Your assistance is appreciated
Old Jan 11, 2012 | 08:35 AM
pettyfog's Avatar
Well.. it depends on whether or not you have the automatic climate control. You are aware there is a difference in heater/ac options, right?
ACC has no blower resistor assy.. it's done electronically in the controls.
How about a picture of the similar looking part with the different connector?
Old Jan 11, 2012 | 08:40 AM
Jimmy91's Avatar
Thanks Pettyfog - yes it has climate control and A/C
I will try to post a picture of the part I was describing once we hit daylight here in the West.
Old Jan 11, 2012 | 08:44 AM
pettyfog's Avatar
I dont believe I've seen a blower problem on the ACC since I've been on here.. several control box fixes. Lotsa Manual htr bad resistor / hi speed relay fails
I suggest your local wrecking yards. All new can be expensive.
Old Jan 11, 2012 | 09:12 AM
Jimmy91's Avatar
I am not able to paste in a picture?
The part has 3 screws mounting it to the black housing - it has a wire feed out of it as well as a 2 or 3 pin connector (I see an orange wire on connector) the main wire leads include a black, brown and purple.
They both then attach to the blower motor
Old Jan 11, 2012 | 09:28 AM
pettyfog's Avatar
Which is why I put up the diagram.
You want to check for 12v and ground in at approp places. Then check the purple/wht stripe for signal. OLD days, used to hook an analog high impedance meter on DC V and look for voltage variation according to Pulse width Mod change.
Might work with DVM, too.. or not.
Old Jan 14, 2012 | 10:13 AM
Jimmy91's Avatar
It turns out my model did not have a resistor - it is a blower motor control module - so we replaced it and we now have air....only issue is that it blows air even while the vehicle is not running or key turned on!
From no air to constant air .... I hope there is a simple solution as pulling a fuse each time I leave the vehicle seems a little far fetched!
Old Jan 14, 2012 | 11:06 AM
pettyfog's Avatar
Good summary... Because IT'S AUTOMATIC CLIMATE CONTROL
The simple solution is to cut/disconnect that ppl/wht wire from the controls to the controller. If blower stops, you need new dash controls, if it doesnt you still have a bad controller.
My guess is: change it again.
Old Jan 15, 2012 | 06:33 PM
Jimmy91's Avatar
You are likely correct, as we removed the HVAC fuse and the blower stops - the speed dial does not allow us to switch the fan to 'off' - and while we have air - it could be more forceful - no real low & high.
Odd since both module and contrl (behind dash) both go at same time?
Will have to figre out a diagram - or go to dealer for the right one since the Haynes manual is not 100% accurate.
Old Jan 15, 2012 | 07:19 PM
pettyfog's Avatar
Obviously the blower will stop if you pull it's fuse. The issue is that ppl/white wire from the control
I dont understand. Is the one I posted accurate or not? It's 99 and you have 98, both are ACC.
