case relearn?
Old Jan 9, 2008 | 04:28 PM
rob2129us's Avatar
rob2129us is an unknown quantity at this point
Default case relearn?
I just changed my distributor. I found my old one was cracked so i bought a good used one and put it in. From what i can see there really is no way of timing like on older engines where u could slightly moved to dist. Is the releran a way of timing the motor any help would be appreciated. my blazer starts right up but is missing bad. THanks Rob
Old Jan 9, 2008 | 05:19 PM
Chevy Lover's Avatar
Default RE: case relearn?
It's hard to answer the question without any vehicle info at all.
Please add vehicle info either in your post or your signature so we have an idea as to year, model, engine etc..
Old Jan 9, 2008 | 06:22 PM
rob2129us's Avatar
I am sorry it is a 2000 s10 blazer 2dr 4x4 thanks
Old Jan 9, 2008 | 07:16 PM
Hopefully you put the new distributor in exactly in the same position as the old one came out. There is no fine adjustment.
Did you have the plug wires off the cap? If you did then it's possibly that you have a couple in the wrong place, causing an engine missfire.
joey
Aug 27, 2012 06:33 PM
bigkeith11
Jul 13, 2012 10:21 PM
Klturi421
Jun 10, 2012 03:45 PM
GM hater
Jan 9, 2010 02:32 PM
chevcamls1
Jan 15, 2008 06:50 PM
