Changed intake gaskets, now i got problems
Old Mar 22, 2008 | 07:03 PM
bodean's Avatar
bodean is an unknown quantity at this point
Default Changed intake gaskets, now i got problems
changed the gaskets. starts fine now i have no heat and it starts to run hot, top radiator hose is cold. just wasted a whole day , has anyone have any idea's ?
Old Mar 22, 2008 | 07:09 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Changed intake gaskets, now i got problems
I had the same problem after doing a water pump, it turned out not to be enuff water in the system yet, let it cool off check the water level again.. I cant pic anything other than that being the cause..how long did it run b4 overheating?? It prob has an air pocket in the system that hasnt allowed the water to flow properly yet... If i`m not mistaking the trick to that is Take off the rad cap jack up the back of the truck higher than the front and then jack up the pass side of the truck also at the same time and that will help with getting the air posket out... Dont sweat the petty things and dont pet the sweaty things!!! you`ll get it we have faith in ya...
Old Mar 22, 2008 | 07:13 PM
rriddle3's Avatar
Actually, you would raise the front, not the back, with the passenger's side slightly higher.
Old Mar 22, 2008 | 07:15 PM
bodean's Avatar
didn't overheat but it was hotter than usual. i could only fit a gallon of antifreeze in it. i thought it should take alot more than that, bottom rad hose was warm and the top hose was ice cold, also heater hoses were cold,
Old Mar 22, 2008 | 07:18 PM
2002XTREME's Avatar
how long did you have it running? it sounds like the thermo may be stuck closed...Did you replce that?and poss it upside down??
Old Mar 22, 2008 | 07:28 PM
thegr81's Avatar
It does sound like a thermostat problem. Did you replace it when you did the gaskets?? If you didn't I would replace it with a new one and see if that does the trick for you, this whole thing just seems like that is preventing any type of flow!
Old Mar 22, 2008 | 07:38 PM
bodean's Avatar
didn't replace it. i'll do that first thing in the morning and then refill it, and jack it up during refill
Old Mar 22, 2008 | 08:56 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
did you let the truck run with the cap off?
just sounds like its low on fluid to me let it warm up with the cap off and make sure the raditator is full
Old Mar 23, 2008 | 10:39 AM
bodean's Avatar
installed new thermostat and rad cap. let it run till it warmed up with the cap off and everything is working fine now. Thanks for all the input
Old Mar 23, 2008 | 05:10 PM
I will parrot the low on water comments. You really need to go through all of the motions to make certain that you have all of the air out of the system. This includes elevating the front with the passenger side slightly higher than the driver. Then run the truck up to operating temperature with the cap off. Don't put the cap back on until you have gone through a few heat cycles (ie. warm up the engine to full operating temperature, then let it cool, add coolant, repeat until the level doesn't drop that much).
