Changing a Pitman arm on a 2000 Jimmy.
You really cannot get a conventional puller on there with the gear box still mounted to the frame. I have always removed the bolts that hold the gear box on and moved it to where I can get a puller on it. This will require you to disconnect the steering shaft, but you should be able to leave the lines connected.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
kornphlake
Dec 18, 2006 02:18 AM
