Changing a Pitman arm on a 2000 Jimmy.
Old May 31, 2010 | 08:06 PM
R134A's Avatar
R134A is on a distinguished road
Default Changing a Pitman arm on a 2000 Jimmy.
Has anybody done this on the vehicle without removing the gear box? Just wondering if somebody has a trick to replace it without pulling the gear box.
Old Jun 1, 2010 | 06:21 AM
You really cannot get a conventional puller on there with the gear box still mounted to the frame. I have always removed the bolts that hold the gear box on and moved it to where I can get a puller on it. This will require you to disconnect the steering shaft, but you should be able to leave the lines connected.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
