check engine light 4wd switch
Old Dec 8, 2016 | 11:10 AM
griffer's Avatar
griffer is on a distinguished road
Default check engine light 4wd switch
96 blazer LT 4wd. My check engine light had been on. Well, I finally engaged the 4wd Hi button due to our recent massive snow amounts. Wallah! The check engine light went away/off. Any clues as to why?
Old Dec 8, 2016 | 12:27 PM
LesMyer's Avatar
ABS and 4WD share some circuitry and power feeds. Without knowing the code(s) for the SES light, we will never really know.
I once worked on a late 70's Olds Toronado where the intermittent wipers would take a swipe across the windshield every time you pressed the brake pedal. Fixed by replacing a taillight bulb and a fuse.
I once worked on a 75 Chevy Pickup where the engine would die (like you shut it off) every time you hit the brakes when rolling forward - but not when standing still or backing up. Fixed by replacing the starter solenoid.
I once worked on a 87 Olds Firenza that would start fine for a couple of seconds and then die like you shut off the engine. Fixed by replacing the alternator.
5000 points each to anyone who can tell me the logic behind each weird problem!
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
