check engine light 98 Blazer
Old Apr 2, 2007 | 02:09 PM
snowman's Avatar
snowman is an unknown quantity at this point
Default check engine light 98 Blazer
hi! Would like some help regarding check engine light on 98 Blazer with only 100000kms .Runs perferct.
Old Apr 2, 2007 | 08:30 PM
marriedguyinlove420's Avatar
marriedguyinlove420 is an unknown quantity at this point
Default RE: check engine light 98 Blazer
Could be a variety of things .If you have an autozone around they will scan it for free and tell you what is tripping the (dummy light).If not look around for a local shop in your area that may do it free or cheap .MY .02 is that it is probably O2 sensor if you havent changed it recently pricey little buggers hope this helps...
Old Apr 2, 2007 | 09:14 PM
2Tone's Avatar
2Tone is an unknown quantity at this point
Yeah, you need to get it scanned and get the fault code. once you get that, then tell us what the code is. otherwise, no one is going to be able to help you. if it is an 02 sensor you need to know which bank its on and if its upstream or downstream. theres 4 02 sensors. so get the code and maybe we can go from there.
Old Apr 3, 2007 | 11:13 AM
snowman's Avatar
thanx for your help marriedguyinlove240 and 2tone ,snowman.
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
